To enable the SSH client functionality, you must enable SSH globally.
You can disable the SSH client functionality on the switch. By
default, the SSH client functionality is enabled.
Enter Global Configuration mode:
enable
configure
terminal
Enable or
disable the SSH client functionality:
- To disable the client, enter the following
command:no
ssh client enable
- To enable the client, enter the following command:
ssh
client enable
